Steves46
My 55 F100 (223 in-line 6) has an aftermarket temp gauge under the dash and what I would like to do is replace the aftermarket sending unit with the original 6 volt sending unit. I believe I found the wire that connected to the original sending unit. So before I do anything else, I would like to determine if this is the correct wire. If I was to hook a jumper wire from the battery to this, should the needle move on the temp gauge after I turn the key on? I would really appreciate any help.
