A 9/02/2014 post was made regarding bench testing a coil . Tom Wesenberg made a reply suggesting placing a condenser across the coil terminals, then connecting a battery to one terminal, and simulate opening and closing of the points by momentarily touching a wire from the other battery terminal to the other coil terminal.
This as usual, is good advice, but I'm curious as to why the condenser is used in this sort of bench test.
donQ
donQ
