Test posting pictures
Only a test.test
436494
The pictures that you added will only blow up to this size. You need to add larger pictures, so that you can successfully enlarge them. Sure, the usual pictures that most Ford Barners add are small, but when you click onto them, they instantly become much larger. With your pictures, when you click onto them, this is what they look like. They should be larger?
Thanks, it is a low-mileage decades-old frame-off restoration that needs a lot of tweaking due to previous owners' neglect. I'm going through the engine now to reset the low end clearances and fix some oil leaks and other stuff. I needed a project during the covid shutdown, and I've always loved the idea of owning a model A... so now I'm hooked! :D
