Test Photos by Mercman
1955 and 1956 Ford Sunliner Quarter Window Frames.
1956 Ford Victoria Quarter Window Frames.
Accessory Hood Trim - 1952-1954 Fords - is this a Genuine Ford Accessory?
Bracket and spring on an Australian 1939 Ford hood mounted the correct way with the spring at the bottom.
Here is an old photo of a 1952 Ford Customline with a different accessory trim piece behind the original Ford badge.
Australian 1939 Ford Deluxe Hood bracket and spring. The spring is in the correct position at the bottom, but the brackets should be swapped around right to left and left to right so that the spring is on the inside, not the outside like on this example.
Yet another After-Market Accessory V8 Badge behind the original Ford Crest Badge. This one on a 1953 Ford Victoria.
Similar accessory V8 Trim for trunk lid of a 1952 Ford. On 1953 and 1954 Fords, the normal trim has to be removed to fit this accessory item?
1909 Ford Model T Touring on display at the Model T Ford Piquette Plant.
The Edsel Affair by C Gayle Warnock
