Frank Miller
Apples to oranges i guess. Secondary spark at the plug is maybe 8-10,000 volts and last approx 2 miliseconds. Two things , you would need to blink really fast AND the flash would be really really bright !!!!!!!!!!!!!!!!!
The secondary is a open circuit due to rotor and plug gap . A timing light would be the correct tool to be used here, watching the flash on the timing pin.....
You need to listen to my training video on the subject :
https://www.youtube.com/watch?v=AkNsa0BK7Zw
I think the real reason is there is not enough current to light the ordinary test light. I've always pulled a wire and watched the spark jump to ground or felt it ground through me. You do not get electrocuted because there is no current behind the 20k or so volts.
