Where I say banger I’m referring to the 4 cylinder motor . Never used it to describe the condition of a car before.
I get the 4 banger slang but I see the banger only reference a lot and it didn’t register. Wouldn’t every internal combustion engine be a banger then? ... and if you only say banger with out reference to number of cylinders couldn’t you assume it was a single cylinder?
Being slang, it means whatever you want it to mean. To me, it's a 4 cylinder engine, stock or modified. Interestingly, while the 4 cylinder is a "4 banger" a 1 cylinder is referred to as a "one lunger". I think it has more to do with how it rolls off the tongue. You want an interesting discussion of "terms" go to the HAMB and discuss what constitutes a "TRADITIONAL hotrod"I get the 4 banger slang but I see the banger only reference a lot and it didn’t register. Wouldn’t every internal combustion engine be a banger then? ... and if you only say banger with out reference to number of cylinders couldn’t you assume it was a single cylinder?
