Richard Lorenz
Many people drill some bleed holes in the thermostat housing so that there is a small continuous flow of water even when the thermostat is completely closed. Maybe 3 holes 1/8-inch diameter. This would give you the correct block outlet temperature all of the time, and would somewhat reduce the thermal shock to the block when the thermostat opens.
