Dennisfly
I recently bought a 35 Ford Standard that came with no temperature or oil pressure gauges from the factory. I can't drive it that way! I bought a set of Bosch mechanical gauges. The water pumps have plugs in them that are not tapered pipe threads and have an angled seat that seals in the port (see pictures 1&2). The probe has the same non-tapered thread that will screw into the port but the probe does not have the tapered seat and does not screw in far enough to hold the probe tight and the angle of the seat doesn't match anyway (see pictures 3&4).
The gauges came with several adapters but none of them are what I need. I can go to the local NAPA and see what they have. Summit Racing has a number of them but I don't know which one is correct. I'm not knowledgeable enough to be able to describe the size and type of fitting, but none appear to be a tapered pipe thread.
Can anyone shed some light on this for me?
