I think my car is mostly original..I never added anything like that. Nothing looks added or newer underneath so I assume that it is all factory.My 36 has a split temp and gas gauge in the dash. It is a nice looking gauge.
If I ay, I would like to ask you about your tires n wheels. I love the way your car sits.
Did you use a dropped axle ? I sent you a message but don't know if you got it.
Thanks Pat
so true...Bad shocks would cause undamped bouncing. which my car does not have. The springs look fine underneath. Nothing is broken. I thing the position of the car looks great.Bad shocks will not change the stance of the car. The spring does.
Karl, there is an instrument company here in Melbourne who I believe could repair your Ford King Seeley temp gauge. Howard Instruments in West Heidelberg. That's a bit closer than the USA. Regards, Kevin.
are there contacts regarding the others? Thanks.I have a 1933/34 dual Fuel Temperature gauge in my car. It works but is not accurate -It reads outside normal range hot at 190F. I have tried the alternate ice and boiling water baths to try and work out any bubbles in it but still reads high. Next year once the silly season is over I will need to get it recalibrated (which I think equals rebuilt!) . I did sent a message to Morris gauges who contribute on this forum if they could recalibrate it but haven't heard back yet. I'm told there are others that will work on them -Karl
highbeams
