Aok
Has anyone tried grafting a new capillary tube to an old MotorMeter Red Ball temp gauge?
Try this link
http://www.ply33.com/Repair/tempgauge
Airsho93, a stock Model A really doesn't need a temp Gage. It shouldn't overheat under normal operation unless you have an issue. When does your Model A overheat?
I wouldn't even take a model a on a tour without a temp gauge. It's one of those things in my eyes that is absolutely necessary if you're going to drive your car. My car doesn't over heat, but I like to know what it's running at so I can tell if it were to over heat. Just buy one of the cheap $30 gauges at autozone. The expensive $85 ones out of the parts books don't work right- I've had 2 fail on me and i know of several others.
The article in Skinned Knuckles is for most of the standard temp guages, The red ball motometer is a totally different animal as it's operating pressure is about 10 (ten) times that of most the rest of the guages.Williamson's Instruments in Arkansas (www.williamson.com) rebuilt three for me some time ago but they were expensive,don't know if they still do them. Jason,
Ron C: It boils over on longer trips on the Hiway. I researched the pasts posts and got some advice about not overfilling it, making sure I am getting flow in the radiator. I have no cold spots anywhere on the radiator. I really think its my lack knowledge about the spark advance and carb setting. I know to retard to start the car and advance the spark to go up a steep hill. Maybe a gauge would tell me more about my driving knowlege and how to keep things adjusted just right. Thanks
I bought my temp gauge at Tractor Supply. I put the probe in the upper hose using two fender washers and part of a toilet supply fitting. Hasn't leaked at all and was installed two years ago. My 180 degree thermostat is located above the probe. Temp stays steady at 180 degrees once the car warms up regardless of the outside air temp.
RonC: I messed with getting this timed for a couple hours. Mostley trying to follow posts and book instructions. I finally would just move the rotor a little at a time to get it where it is now.
Your idea is so simple and smart. I am going to do as you described to see where it's at. That is a cool method. I like it. Thanks
