The attached article is how I installed a temp gauge in my Victoria.
Tom Endy
How much temp drop should a good radiator measure? I suspect the one i am working on is shot. It drops only about ten degrees when measured with an hand held IR measuring tool.. I am thinking 20 degrees might be a target?
Since no one else mentioned it it.... [FONT="]Water Outlet[/FONT]
Not to highjack this thread but, is that the way the crankcase vent tube is supposed to be routed?
I plan to install a lower water inlet with a port to install a water temp gauge. . . seems pretty easy. Looking for any advice/guidance.
My A had the breather vent tube routed along and inside of the left frame rail under the drivers seat instead of below the car to take advantage of the draft. I still wonder about that.
