Techniques to set timing...
bobioknight
Hey guys, I am confused about timing, the manual for my 1957 thunderbird 312 ybock states 6* at 500rpm. But I see people posting that they run better at 12*. I hope this is not too confusing to read.
So I have been experimenting with different degrees but I don't want to hurt my engine, economy or overheat, so I am curious if I am doing this correct.
So I connect my timing light, my vacuume gauge and remove the vacuum advance and plug the carb port, loosen my distrib and get ready for adjustments. Start the engine, let it warm up completely. Set my timing light to 12* and adjust the dizzy until the marks are at tdc.
As I adjust my dizzy the rpm's increase so I continually increase or decrease & the vacuume increases and decreases depending on the direction I turn the dizzy. I make little adjustments at a time allowing each adjustment to kinda balance out.
So what I experience is when I am at 12* at 500 rpm, I don't have as much vacuume as when I am at let's say 8* at 500rpm. Also at 12* my idle is a bit higher than I can adjust the carbeurator down to so I can only adjust the idle screw down to 500 rpm and no lower. If I set to 8* then I can lower my idle by adjusting the screw on the carb way lower. At 12* it seems to be a little harder to start like the starter has to pickup speed to get it going. At 12* my vacuum is at approx 18 whereas at 8* the vacuum is a bit over 19.
So my first question is when I am adjusting my initial timing, do I adjust the idle keeping it at a constant 500rpm, I ask this because as the idle rpm's change the timing mark changes as well, is this normal. As I advance timing, the rpm's my go to 550, when I reduce the rpm's back to 500 I may have to adjust the timing a little more until they both are balanced depending on the number I am trying to hit.
Second question, total timing, let's say 35* at 2500 rpm, is this the most important timing setting. Should I set this first and see where my idle timing ends up.
Third, if the manual calls for 6* should I set my timing to 6* if I have the most vacuum at that setting. Or do I stop focusing on hitting an exact timing number and just focus on vacuum by advancing the timing until the vacuum stops increasing?
Forth I have read, keep advancing timing until it pings on load then back it down a little, well I am not pinging yet at 12*, does that mean I could keep advancing further like to 16*, but although that might not ping I expect my vacuum would be much lower the further it is advanced making it even harder to start.
Fifth, timing vs heat, if I set timing to 6* I think it runs hotter and less fuel economy. The more I have advanced the timing I think it runs cooler and I feel my fuel economy increased. So do I just need to find a good balance, like 8 or 10, or the highest vacuum?
people say "it just sounds happy" well that's tough, because the more advance the happier it sounds because the idle is going up which makes everything sound very smooth, idling down at low rpm's sounds a bit rougher, but I have never heard pinging or knocking, I always run premium fuel so maybe it covers up timing issues.
Every engine is different, and Y blocks respond more than many when timing. Most times a 312 can be timed with the vacuum gauge alone, leave the light on the bench. Advance timing to the greatest amount of vacuum, then back off the dizzy about 1/4 inch, or 1/2 inch of vacuum. Test drive for ping under load, and ability to start. If all is well, drive it a while to check for heating. It may want the mid grade of fuel, but it may be more fun to drive.
Also...., yes, it's true that more spaerk advance makes the exhaust temps cooler, and less spark advance makes exhaust temps hotter. Proven fact.
Sal
Even identical engines seem to like slightly different tuning. Tolerances, wear, density altitude all play into that, as does running premium. I wouldn't worry a lot about 10 or 12 degrees initial, or 32 to 35 total, or all in by 2500 or 3000. If you're racing, that's important. For just driving, if it starts easy and runs well, doesn't overheat and doesn't ping, just enjoy it.
Ok, willing to try it, so does it matter at what rpm I check vacuum at, should I check vacuum at an idle speed 500rpm or would a smoothie 1000rpm be better.
I would say idle speed between 500-650rpm would be best, depending on the type of transmission. I do not remember about the older automatic transmissions anymore, but most newer auto's the idle speed is set with the trans. in drive. this usually works out to about 600-650 in neutral and about 500-550 in gear, but does vary from vehicle to vehicle.
Ok so I put the vacuum gauge and the timing light. I began advancing the timing until the vacuums topped out at 20 point Something. I backed it back down to 19 after adjusting the idle back to 500 Rpms. I checked the timing with the light and it was reading 16*. I thought it was a bit high but ok it was running smooth, no ping or knock so I adjusted the idle screws in until everything sounded nice and smooth.
On the road just cruising no ping no knock. I was driving on a straightaway so I punched it and just before it shifted up, I heard pinging. I pulled into a parking lot popped the hood and backed off the dizzy about quarter inch turn. Ran around the block again, in the same location I punched it and just before it shifted up, I head a slight ping but much less, so again turned the dizzy another quarter inch and ran around the block, same place upshifted and no ping.
Just ran a short trip on the freeway, ran it up to about 3700rpm no ping, ran nice and smooth. Got off the freeway while sitting at the light, idle smooth, no bouncing, accelerated perfectly. Ok, so far so good,
Ok should I leave it there, or should I retard the dizzy another quarter inch turn for good measure. So far, no ping, smooth idle and quick response.
I would nail it right where it is.
Times 2
Hook up your timing light again and with the port for the dist plugged see where the initial timing ended up. As long as it isn't out in left-field somewhere save that number for next time.
Double check that the points are gapped where they belong too. If they're off at all it will affect the timing. I prefer using a dwell meter (if you have one) for setting the points.
Sounds good, I will record the numbers. I am running the Petronix ignition.
Question regarding fuel and timing. I am running premium fuel, could the higher octane fuel mask/hide a pinging engine. I don't mind running premium but I don't want there to be an underlying issue that is hurting the engine.
Should I be tuning by ear with regular fuel to see if there is any pinging, make those adjustments, then run premium if I choose to.
