40cpe Well-known member Feb 23, 2025 #2 If you are referring to a leakage test, filling the bowl with gasoline and placing the carb on a white paper towel overnight and check the fuel level and look for stains on the towel is how I've done it.
T Tim Ayers Well-known member Feb 23, 2025 #3 I’ve read a few times to use rubbing alcohol since it dries quickly and completely. Haven’t tried it yet
ford38v8 Well-known member Feb 24, 2025 #6 Use Maker's Mark. It helps pass the time while watching a dumb carburetor all night.
glennpm Well-known member Feb 24, 2025 #7 ford38v8 said: Use Maker's Mark. It helps pass the time while watching a dumb carburetor all night. Click to expand... Good way to get in the right spirit!
