Got a car. Actually more of s speedster but it has a model A rear axle and brakes. Last time I drove it, I let off the clutch, and nothing happened. Messed with the clutch linkage a bit, though I think it was fine and tried again and nothing. Then for some reason I pumped the brakes and it took off and I drove it around slowly a bit.
Anyway in trying to figure out what happening I realized I wasn't sure how a differential is supposed to act. With one wheel off the ground and the ****** in neutral, I can turn the rear wheel but the drive shaft doesn't turn where you can see it at the speedometer gear hole on the torque tube. It should, shouldn't it?
With the wheel off the ground, and the ****** in gear, if I turn the engine with the crank the rear wheel turns.
What on earth is going on?
