NormC
I know that most if not all of you recommend the taper of the axle to be clean of any material prior to installing the brake drums, but I have a question concerning the use of an Anti-Gallant material applied to the taper.
Does anybody have any experience using an Anti-Gallant on the taper?
At work, we will apply an anti-gallant to one particular nut and washer. We will torque this nut to 7,000 in/lbs and then “stretched” and additional 45 degrees of rotation.
I have cleaned the axle and drum and lapped the two surfaces.
Thanks,
Norm
Thanks,
Norm
