The generator really doesn't care about voltage. It'll work as is.
Do a search on the subject. Fellow FordBarn'er Mr. Purdy Swoft has done it to a Model-A or two that he owns. I think it basicly boils down to changing over to a 12 volt battery.Plus, a 12 volt coil and light bulbs.
Probably a little more to it then that, but I'm sure someone with more info should jump in and give you the correct procedure.
Bob-A![]()
Can you elaborate on that? You are saying I can use a "6V" generator on a 12 V System and it will give out 12V ? And what about the cutout? Thanks Bill G?
Bill, like the fellas said, the generator doesn't care about volts. It'll work as is. If the battery is changed from positive to negative ground, then it'll need to be re-polarized/flashed thats all.
