Barry,
I have a suggestion below... and posted in another thread reply some time ago that is in my opinion the best solution for you. I've posted the link below or you can search on "gear shift lever bend Larry Shepard"
In a nutshell you would relocate the pin redrilling the hole for the horizantal pin that is in the shift lever to the gearshift top. You can rotate the shift lever counterclockwise and redrill at the desired rotation which allows the lever to be off to the right out of the way. I would suggest carefully knock the cover up and pull the gearshift up slightly and have someone knock out the pin. I would then rotate the lever around for best fit, mark on both sides of slot on trans top and then drill to match.
Link below from my previous post on this.
http://fordbarn.com/forum/showthread.php?t=134717&highlight=shift+lever+bend+larry+shepard&page=2
I honestly would not bend the shift lever to fix your problem.. I think you will find this a better solution. The guy who I did this for was over 6.3... and it did the trick beautifully. Takes a little use to shifting with the lever to the right but he could get it out of the way of his legs and have room.
PM me if you have any questions.
Larry Shepard
03-23-2014, 07:59 PM #
22 larrys40
Re: Bend the gear shifter?
fiddlebits,
A couple of years ago I modified one on a coupe I sold to a very tall fellow. He had so much leg that he couldn't use 1st. I took a new repro
shift lever and redrilled the pin hole for the slot in the
shift tower.. I used another
shift tower for a mock up... and dislodged the bell and redrilled the
shift lever hole. No need to weld up the old hole, just cross drill at your selected placement. It placed the gear
lever far over to the right but it did the trick for him in getting leg clearance. There's only so much in a coupe!
I thought at the time that it was way better than bending, didn't mess up any chrome.. and did the job professionally and without stress to any components. If you want to go back no big deal..just install your old
shift lever or whole tower.
Best of luck!
Larry Shepard
