pjdeb Senior Member May 12, 2023 #1 It is confusing me. Everything I read says generator on my 1923 T should come off with three bolts. I see three long bolts. Left, under, and right through the oil breather. Removed all, but generator does not budge. What am I missing?
redmodelt Well-known member May 12, 2023 #4 Yes it is only 3, you can see them from the front. Sounds like you took out the bolt at the bottom of the housing to pan.
