tail lite bulbs
The 1W white LED beads are the same as the following
https://www.ebay.com/itm/New-Wholes...814124?hash=item46b20b94ac:g:yfUAAOSwf8dfIKPV
The 10W red LED COB chips were purchased from the following. I chose the bright red ones that operate at 6-7 volts. Perfect for a stock Model A.
https://www.ebay.com/itm/10W-watts-...e=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
I do have LED headlight "bulbs". The ones I have were purchased a few years ago and work well if you have a reliable ground. They are for Positive only systems. The parts houses are now selling an improved version that will work on 6 to 12 volts and either positive or negative ground systems. I have not used the new ones but I think they are a better choice for Model A cars.
