J jtminor Senior Member May 24, 2024 #1 Can someone please tell me how to connect these tail light wires. Attachments Tail lightr connector.jpg 25.3 KB · Views: 148
petehoovie Well-known member May 24, 2024 #2 jtminor said: Can someone please tell me how to connect these tail light wires. Click to expand...
cmbrucew Well-known member May 24, 2024 #3 They look like aftermarket Fainstock bullets. They may plug into original Ford connectors. Bruce
R restoman Senior Member May 24, 2024 #5 Bob Drake had them recently, also probably Third generation.
tubman Well-known member May 25, 2024 #6 I will note that the "bullet" connectors shown look different from the original Ford units. They will probably work, but.....
Kube Super Moderator May 25, 2024 #8 tubman said: I will note that the "bullet" connectors shown look different from the original Ford units. They will probably work, but..... Click to expand... Yep. They will work but you will need to grind down the diameter a bit. As is, they will not fit the connector.
busmania Well-known member May 25, 2024 #9 I was able to get them to fit recently without grinding. They are just tight.
JayChicago Well-known member May 25, 2024 #10 Aren’t those the light bulb contacts? Don’t look like bullet connectors. Wire looks correct for Ford taillight.
V vincent Senior Member May 25, 2024 #11 They do look like the british Lucas connectors that were used on all british motorcycles between the 50s and 70s - should be easy to find.
