1931stdcoupe
Has anybody successfully used a hand held non-contact laser tachometer to measure engine rpm? If so, where do you put the reflective tape?
That's true Alex, but that's a good place to get your hand chopped off!
I know that it would be impossible and dangerous to try to put reflective tape on a running engine Katy! I just didn't know if you would have to get too close to the spinning fan to use a laser tach...Don't try and put the reflective tape on when the engine is running.
The hand held unit doesn't have to be close to the reflective tape to work. Give it tryers and you'll find out if it will work or not. Simples.
