Don't they represent the hood support brackets found on 28-29 radiators?
Does that radiator accept an original style cap?
Typically no, but how I got around it for one of mine
I cut off the small neck from the top of the aluminium tank and then had to machine a new larger one with an O-ring to seal out of aluminum and weld it in the proper location on the new radiator top tank.
Next I ordered a replacement brass radiator neck. Then more machine work, made at hreaded steel insert for the brass neck. The brass neck and steel adapter were soldered together.
Now you can thread the two together, O-ring sealed and install the stock A cap
Yes mine is a 31 but all of the aluminium radiators that I saw when looking for one had small threaded spigots and the one on mine was a metric thread.
Also not in the correct location for the radiator shell
Hope the 1EarlyA's fit's better but they can be made to work![]()
Also not in the correct location for the radiator shell![]()
How far out of whack was the location relative to the opening in the shell?
I hadn't even considered that possibility.
1/4"-3/8" too far to the rear
I've only seen them in the past few years. As people complain (send them back to FleaBay sellers) they will get better. Just modifying them to work doesn't cost the maker/seller money so they have no incentive to get the problems fixed.What is sad is that these radiators look to be somewhat well made. Just a little more effort to set the jigs for fit and they would have a great product.
Chinese made garbage that takes an American to make it correct(insert American flag here
