JM 35 Sedan
An earlier post on this subject got me thinking (and that could be dangerous
). Does anyone make a T5 conversion kit, that would directly replace an early 3 speed floor shift transmission, without the need to remove/cut the center of the X member? In other words this conversion would bolt to the engine via an adapter and then to the closed driveshaft, through the universal joint, without the need to modify anything else on the original drivetrain. This type of conversion seems like it would be the "cats meow" to me providing nice smooth gear shifting with an overdrive gear. Is anyone possibly working on something like this? I would never cut the frame on my cars to install a T5 but I would do a direct conversion without the need to cut anything.
Note: Maybe I should have said T5 or any other good 4/5 speed transmission with OD
