thirt4
Well, it was just discovered that during a "clean-up" session last fall during the restore, the original speedometer cable was apparently tossed out.
The cable I will now need anyway must go from the "new" BW T-5 transmission, up to the back of the stock 1934 Ford speedometer.
Where would I get such a speedometer with the correct connections?
This is not the electronic transmission. (Henry did not have "electronics" in his cars as I recall.)
Thank you.
Thank you.
