Bored&Stroked
Just so you know, you can't just drop in any T5 transmission without a lot of other work:
1) It won't fit in your stock frame without semi-major frame modifications in the middle area where the transmission mounts.
2) The stock setup uses a torque-tube and driveshaft that will not bolt up to any modern transmission. To deal with this, most folks will go to an open driveshaft style setup, which requires specialized parts, welding and the addition of stronger rear-end mounting bars than the stock radius rods.
3) A custom driveshaft has to be fabricated to replace the original torque-tube and driveshaft.
All of this is major work and should only be considered with the body removed from the frame. It is all doable - if you have the expertise, time, serious $$$ and/or find the right hotrod shop to do the work.
With that said, I feel your pain . . . I have rebuilt more Ford 3-speed transmissions than I care to talk about. I know all the "tricks" to make them more reliable, but I still don't really like them. On some cars/builds I will go the T5 route . . . on others I will continue to use the 39 Ford 3-speed and add a Columbia rear for better highway gears.
It all comes down to trade-offs . . .
