T radiator A chassis
1ton
I have a '27 roadster body just sitting around. Recently acquired a running '30 chassis. I'm thinking about mating the two together. The plan is to keep the chassis all original, mechanical brakes included, and use the original T hood and radiator shroud. My question is about cooling. Since I don't have a radiator and would have to buy a new one, would the smaller radiator cool the A engine enough or should I plan on a '28 '29 radiator and shroud instead.
The hood of a T is slightly shorter than an A if i remember correctly.. So you might have to move the rad' back or get creative. The T rad' is slightly wider too so moving it back an inch or 2 should allow it to sit on the frame rails nicely.
Disclaimer: this info' is based on old memories and may not be the most definitive guide ever.
