t not running right i think need help
mike37cdn
I have a 26 4 door it seems to hesitate as it is picks up speed it does it on mag or battery the coils are rebuilt ,tried an other carb got the same thing . it seems like a miss but its like it short out for a second it has an anderson timmer I had it of but it seems to be clean with little wear not shur where to go next with it any helpwould be great thanks mike
Coil Box wood has carbon tracks? Hard to see, you can try looking in the dark for stray sparks. If you can try another coil box that would help.
Fuel flow? Is the fuel flowing to the carb ok? Pull the carb bowl and catch the gas coming out. Look for good flow with now stoppages.
