Guys, one of my T coils is oozing oil when it warms up. Is there a trick to removing a or all coils. It is a 1924. They are wedged in there so tight I can't get enough purchase on it to pull it up. Thanks.
If you can get any of them out, the rest will be easy. Wiggle as J Franklin said, helps. Try not to lift or pry by the points. That will mess up the adjustment.
