flathead 53
Anyone do A t-5 install in A 53/56 f-100,
update on the T-5 swap in my 1953 f-100 flathead. finally got it all together , I used an S-10 transmission with A 53 bellhousing from A f-250 larger bolt pattern , had to re drill two new holes for mounting in the transmission face , also had to slightly elongate two holes in the transmission , truck has A 392 rear ,now going 50 mph doing 2300 rpms ,put in OD ,rpms go down to 1600rpms , need to fine tune the clutch linkage , clutch grabs a little high, I also added power steering to the truck from A kit from CPP, every thing looks stock ,but it drives like a mid eighties truck .
V8 Coopman, you are correct , first gear is 3.50, that with A rear end 3.92 , spins tires easy.
I am probably going to install A nine inch rear from A 57/72 f-100 or A mid nineties bronco rear with A 354-1 ratio, these rears are A perfect fit they are 61 1/4 wide and many ratios are available. so far I am pretty happy , the truck has power steering , and wilwood disc front brakes , all else is stock ,just want A good driver,
