Gary in Mozarks
what sort of modifications to the K frame is necessary to put a t-5 in a 39 ford frame?
That looks pretty nice Dirty Dan, but I'd still try to get something across the topside of the X member to tie it together.
Use the rear from the first generation Broncos(don't remember the exact years). Fits perfectly in my 39 and has 5 1/2" bolt pattern. I used a Chassis Engineering kit to install it. I installed the aluminum 3 speed OD from a mid 80's Ford pickup with the 300 cu. in. 6. Only had to make minor modifications to the center section of the frame. Bolts up to 49 - 53 bellhousing. With a 3.70 rear axle, I turn 2500 rpm at 73 mph. Also the shifter is almost exactly in the stock location. With my 39 shifter grafted on, no one knows the difference.What are you guys using for rear springs and rear end? I assume it will be something with longatudinal leaf springs? Ive heard early bronco but I don;t know what year.
