One end is for use on the band adjusting nut, the other 5/8th, which is a common size on the Model T. I would have to find one to check. I use modern tools on my T's so don't have one handy. The No. 1917 wrench came with every car tool kit so are very common, think 15,000,000+ made. 5/8th is kinda strange. The only bolt heads it might/would fit is the retainer on the timer and water inlet/outlet. Most all the rest of the nuts and bolts take a 9/16". The only other wrench that came in the tool roll was the adjustable.
