T 170 transmission wanted
xelhan
Whittier
CA
I'm looking for a Ford RTS 3spd transmission with OD, fitted to Ford F150 2WD Pick Up’s 1984 - 1987, also called Tremec T170FT RTS.
I will install it in my 1934 Ford Tudor that has a slightly modified 1948 Mercury engine and 3.78 axle ratio and after some consideration I have found that I would like the "code B" version of this transmission, which has ratios 3.25, 1.92, 1.00 and 0.78
This very transmission is recognized on the ID tags three first characters RTS followed by a two character alpha code, AD, AE, AJ, BJ, BP, BU, BV, BZ or CS - any of them will work. The Ford transmission code "B" is also printed at the bottom of the VIN/GVWR/Tire information label - applied inside the driver’s door opening. I also need the shifter.
If any of you have one or know of one for sale, please let me know.
mail: xelhan@hotmail.com
Thanks
