t-170 FT behind a flathead
Take a good look at the ratios between the gears - Some of them can be quite long and makes for awkward shifting in some situations - Also the gears are thinner than the Ford muscle car toploaders and are not as bullet proof
Hey, John - good to hear from you and that all is well. Plenty of info on the HAMB on using this trans as well but I think most everything has been covered here. Please give my best to your lovely wife ....
Tom T. ............I'd like to try this t-170 as I could keep my banjo rear which is rebuilt and has the upgraded brakes. I have been running a '39 top loader for @ 10 years with a 3.50 gear. It would be nice to have an OD. The only time this car has been on a trailer since it was built was when we went to the Barners Bash a couple years back. Hope to see you in Charlotte next year..........John
I am trying to determine which ratio T170 ft TOD Transmission I have as the tag has gone. Can someone tell me how many teeth the OD gears have for the different ratios.
The trans I have has 18 teeth on the small gear on the main shaft which I gather is the OD
gear. Thanks
Why not put it in gear, turn the input 10 times and count the turns of the output? 7 turns = 0.7, 8 turns = 0.8. Compare the number with the available ratios and decide which is closest.
Sometimes the old school back to basics methods are quickest and easiest.
Mart.
There is a code on the side of the case that will tell you the application, and thus the gear ratio of all the gears,
This is a modified 8BA steel bell housing for the T-170. I used a stock clutch with the proper disk
Do you remember what model the clutch disk you used was for? I am doing this swap in a 50 shoebox and need a 9 1/2" clutch. I found one for a 74-78 mustang 2 I'm going to try with the stock pressure plate.
