How does my Cadi know if I use synthetic, but it does. If I use regular oil it will indicate oil life used up at about 3000 miles, If I use synthetic it will indicate oil life used up at about 8000 miles.
HOW do you BURN an INTAKE valve?????----NEVER-EVER saw that!!!!
They run as COOL as a CUCUMBER!
Bill Troublemaker
I just now topped off the tran and rear end with Sta-Lube Syn-Go (OEM grade) 75 - 140 weight oil. I added about a pint for the transmission. I will taking a short hop around town tonight to test the shifting. I only had to add about 3 ounces to the rear but there has been no issue there anyway.
This is the best product I could get in short order here in Mississippi and it cost me a bit ($60.00 for a two quart bottle). I'll let folks know what my observations are as soon as I put the Old Girl through her paces.
John,
you could have considered mixing it 50/50-best of both worlds.
Synthetic oil has consistent sized molecules
Dino oil has random sized molecules
Hybrid synthetics are a blend of both,molecular consistency provides stability in the oils properties,making is superior to Dino oil...but that's it,there are no wizards in it..
I ran a truck fleet on hybrid synthetic and extended the drain interval to 30k,matching the oil change with the DOT 90 day inspection and saved thousands with no risk of engine damage...before that they were on a 15k drain with dino oil,forcing the truck into the shop twice as much..managed to get a 'thank you' from the owner,the cheap *****..
