john mullen
I want to see if anyone has installed a sway bar to there 48 - 52 f1 ford truck front and rear axels I want to do it and hope to get info on what, where, who.
...If you have parallel front/rear springs and an I beam solid axle, you most likely do not need a "sway bar", you need a "roll stablizer bar" to control body roll in lieu of misalignment of the body in relationship to the chassis..
A sway bar is generally connected to the chassis/frame and suspension via a solid connection.. This type of a bar is also called a track bar and/or panhard, it keeps everything in alignment.. Generally speaking parallel springs do the same thing.
A roll bar is a form of torsion bar, that generally is attached to the frame and suspension via movable links.. The purpose of the bar is to limit body roll..
Ahgggaaa now there is a new set of springs involved, gas shock package and radial tires, what happened to this info on the original post? All of these should have reduced the roll considerably, what type of feel do you want, that Euro ride with no roll?
this is my truck .I built it top to bottom, paint, engine, driveline, interior ect and don't need anybody to do a dam thing for free. some of you guys sound like you have nothing better to do![]()
