When you say that you are looking for 'sway Bar' info for a '36 Ford, do you mean tracking bars to keep the chassis in line with the body, or body roll control.... Two completely different things that many people are confused about.
I have attached a pix of the track bar (panhard) on the rear of my 36 coupe. My rear end is a '46-48 Columbia that came from the factory with a rear tracking bar. Starting in '40 Ford started to use body roll bars, commonly called sway bars on the front of the DeLux cars. All Ford built cars '41-48 had the body roll bars on the front.
Some of the aftermarket vendors sell a kit for the front, be careful what you look/ask for, don't get the two bars mixed up. If you truly want a sway bar, then ask for a track/Panhard not a sway bar. Coil spring suspensions will generally have both, parallel springs will generally only have a body roll bar.
