Swap meet Finds ?
paleot
I found a couple of things at Conroe I have some questions about. First I have a Winfield marked cam # on end ¾ no line between the three and four and a 1 by itself anyone have any Idea what the specs on this cam may be? Second question I bought a set of Offenhauser heads # 375 stamped on them any Ideas on comp ratio? Third Question,I bought a Fenton two deuce intake with what I thought were 94s the front has 1 1/16 stamped on it the rear has 1" stamped on it both power valves have blank valves installed when the front carb is wide open throttle the back carb is only ¼ open what should that measurement be? Any Ideas what the jetting should be on primary and secondary? Previous owner said it ran terrible on stock motor! carbs look new condition with a fresh rebuild. Long post with a lot of questions any help will be greatly appreciated.
Tony
The carbs are slightly bigger units of the 94 style. That type of progressive linkage does not work on a 2x2. Power valves should be in the range of 3.5 or 4.5 in both of them. omo ken ct.
