John,
IMHO Strombergs are easier to dial in. Occasionally a leaky Stromberg power
valve will mess with you. As you know these power valves are a simple mechanical
device......tiny spindle,seat and teeny spring. It's best to NEVER assume that your
new fresh from the blister pack valve is good and certainly never trust a used valve.
Each one should be checked for leak down before use....dialing in is then lots easier.
Throttle arm on a Strom is above center on Ford 94 etc arm is below.......
both operate on a rearward pull. With some minor linkage lengths one can fit up in
the others place.
Charlie ny
