Clem Smith
Breaking speedometer cables (2).Disassembling 1930 SW 35001 Oval Speedometer, 10K since 1965 "decals/rebuild".
How do you remove the magnet from main shaft?
Shaft has spider gear at bottom turned by mating spider gear & speedo cable.
I read threads I can find, including link to Model A House and Les Andrews Speedometer Service Hints, most are for basic decal replacement . Drawings helped.
Have odometer dial, speed indicator wheel and trip mileage wheels removed.
Magnet appears to have a flat spring clip holding assembly to shaft.
Does this simply pull out, releasing magnet?
Magnet and shaft with bottom spider gear turn but still slightly stiff…assuming old grease/corrosion in mid shaft worm gear area. Would like to refresh lube/grease throughout.
Also, what size is stake pin that holds odometer dial assembly in place? Need source for this pin.
Thanks
Clem Smith
Foresthill CA
Thanks
Clem Smith
Foresthill CA
