Things begun to snow ball once I decided to run juice brakes and a T-5!
I used your their parralel leaf spring kit,shocks and sway bar along with a Buick Grand National rear end. It's backing plate to backing plate was Identical to the original ford banjo I took out. Things begun to snow ball once I decided to run juice brakes and a T-5!
An anti roll bar works very well on these cars. You might have to fabricate it yourself though. You don't want to do any cutting, welding or heat bending on a factory one. They are a torsion bar and depend on the heat treat in the bar to work.
I guess I forgot to tell my front sway bar that it wasn't supposed to work after being cut and welded. It's been that way for over 88,000 miles and still working fine. My avatar is not a burnout it's a sideways drift so you can see the sway bar works fine
I think I see my future...
I said I wouldn't change anything until I had the car a year and really figured out where I want to go with it.
The welder knew what he/she was doing...
I don't know if this is possible on a 36, but on my 39 coupe, I installed a 40 Deluxe sway bar in Front. It required removal of 2 rivits and 2 new holes to be drilled. This made the Best improvement re sway/roll
