Supporting trans w/o engine in car
Colonel
I need to pull just the engine out of my car for repairs. I plan to leave the trans and bell housing in the frame. With the engine out, I will need to support the engine so I can move the car to another shop for work. Does anybody have a method for supporting the trans safely without damaging anything while allowing for me to put the car onto a trailer for travel.
Thanks
I used a 2 x 4 from door to door and a 1" ratchet strap to support the ******. Cheap, quick and easy support.
Here's a thread with my picture of the ****** support.
http://www.fordbarn.com/forum/showthread.php?t=31128&highlight=******+support
Small ratchet strap to ****** and frame
More work, but you......
Could remove flywheel housing from motor.
Leave bell housing on trans.
Bolt the bell housing to the flywheel housing and bolt the flywheel housing to the motor mounts.
Here's another ****** hoist tool I made to lift and hold the ******. I also made an aluminum cover plate and handle to keep junk out of the ****** and to make it easy to lift.
I did something similar to Tom's work but used an all thread that I bent into a "U".
