Super B+ Distributor
No product appeals to everyone. If this one isn’t for you, keep your money in your wallet and carry on.
DOES ANYONE KNOW Means garage PHONE NUMBER! Address? Website with info?
Seems that this info is being kept a SECRET!
What info is on this Facebook page?
I do not do FB
Maybe someone could copy info and post it so we could read the information?
Thanks
I don’t have FB either, but from FB just click X and found phone # 417-754-8637
Means Garage. 3783 S 21st Rd Dunnegan Mo 65640 Jandshotrodasylum.com
From their website the phone number is good ! Caution the website is for hot rodders
Another helpful hint:
Note : This is using point ignition.
If your ("clip-on number one plug) timing light is acting "flakey":
Two different timing lights had this problem:
1. Innova 3551
2. 1993 SunPro "dial advance" model.
1.Will not turn off with the on /off button switch.
2. Timing jumps around.
3. I re-routed wires away from distributor and it was better but still not right.
If you are using copper wire spark plug wires try "carbon core wire" plug wires.
Fifteen years ago I also had problems with FSI electronic distributors when cranking engine the starter would turn very slow and "buck" against itself.
Turning off key allows faster cranking and no "Bucking".
Replacing copper core wires with carbon core fixed the problem.
NOTE: Both timing lights work fine on the 1988 Toyota Cressida (with carbon core wires)
fifteen years ago i also had problems with fsi electronic distributors when cranking engine the starter would turn very slow and "buck" against itself.
Turning off key allows faster cranking and no "bucking".
rfi
