Houdini
Seems like I fix one thing and then another problem pops up. I thought my petcock on my Stainless Steel water pipe was leaking, but it turns out that the threaded fitting that appears to be welded or soldered to the pipe, where the petcock drain screws into, is the problem. It looks like a leak by one edge where it meets the water pipe.
I could just buy another water pipe, but is there a way to solder it. I don't have any skill in welding, nor the equipment, but I do have a torch. If it can be soldered, what type to use. If this is not a good idea, then I'll just get a new pipe.
