markyb
I've had an intermittent problem with a no-spark issue and the engine cutting out while driving. It seems to happen occasionally when I was adjusting the spark advance, but not always (making it harder to diagnose). IT happened again today, and I suspected the wire leading the points below the top plate of my modern points, so I added shrink tubing to the entire length of the wire, and while checking for continuity on the points arm it was shorting again. I removed the top plate, and while checking for continuity I noticed that it shorted again when I pushed the tester probe down on the bottom plate. Sure enough, it appears to be the bottom plate making contact with the inside of the distributor housing. I could see the arc spots on the bottom section that connects to the ignition wire. It's such a critical issue, I was surprised to see so much metal on that part of the plate, making a short very likely. I'm going to grind down at least an eighth inch to make sure that there's no chance for continuity there again.
My camera wouldn't focus real well on the part, but you'll get the idea...
