sub Frame 28-29 roadster p/u
Gerryde
Hi folks iam in the process of putting the sub frame togeather on my 28-9 r/pu
could someone please tell me the very front off the sub frame has a risser for the floor boards to go onto,now the bottom part that is conected to the main sub frame dose that go under or over top off the main sub rails. It is the part that holds the front quarter panels on to the sub frame.
Many thanks Gerry(NZ)
I'm not quite sure what your asking, but the short cowl subrails fit under the main subrails right at the cowl posts, the main subrails are stepped to fit over the short front ones. Then the 90 degree cowl post brace sits on top with I believe 2 bolts that sandwich the whole assembly to the wood blocks and the frame if you need pictures pm me your address and I will send you some. Ian
Hi manny thanks for your replys, i have been out and yes its all done.and fits really good thankyou. I dont know what i would do without the knolage of this fourm.Cheers Gerry (NZ)
