I have a new pop out switch and cable with the thick ignition cable clamp.
Issue is the stud on number 8 cylinder is the shorter version the the clamp will not work with that size stud.
Question?
Does anyone think I should remove the one stud and replace it with the long version (4 1/16") stud - or install the thin ignition cable clamp?
I don't want to create bigger problems by removing the stud.... not that i necessarily would but I like to ask the 'experts'
Thanks!
Question?
Thanks!
