Bill O'Brien
- City
- Pottersville
- State
- NJ
- Price
- 84.99
Stud Drill Out Kit
This is the kit sold by Brattons which was designed by one of our own board members!
It is an excellent kit which makes it quite easy to drill out a broken stud.
This is a high quality set consisting of 10 pieces that are needed to drill out a broken head stud. Using the 2-locator plates allows you to accurately locate the drilling fixture over the stud that is broken off. Designed by a mechanical engineer for use on his car. Kit includes detailed & illustrated instructions. This kit contains the tap and bushings for the standard thread studs.
Please note I have included the spacers which are used to secure the plates to the top of the block. Washers will also be included. These were required at the base of the studs used to secure the plates. The holes in the plates are a bit too narrow to fit all of the way down to the top of the block.
The drill bit will NOT be included. The one that came with the kit was TERRIBLE. I recommend you purchase a 3/8 inch Dewalt Cobalt Pilot Point bit. Ate right through the broken stud within minutes.
Shipping will be $9.99. I can ship it out asap.
