Billybob57
1931 model A sat for 20 years. Motor was stuck. Added ATV and MMO through plugs and then could rotate the motor back and forth 200 degrees but stops at the same point. Took head off and valve cover. Appears that some valves are frozen to the head as some never push open. No. 4 cylinder valves never open. Questions: Tricks to get valves freed up? The head studs are in good shape. Should they be replaced anyway? I'm worried about breaking one.
