Got it running. Kept prying down on the valve spring with the tool against the block of wood. It started moving a little so I had my wife crank the engine over using the hand crank. Each time the valve would move a little more. Finally got it to snap closed all the way, then kept turning the engine over with the crank while spraying the Break Away thru the valve spring on the stem. After about 5 minutes of cranking the valve was moving up and down smoothly like the other valves.
It helps to get the tool as far to the bottom of the spring as possible so the coils don't collapse when pushing down.
Lots of spray in the plug hole directed at the valve, thru the exhaust port at the stem & thru the spring also at the stem.
I have only driven the car a few miles this year due to other priorities (selling rental house, new well etc). I started it about 2 weeks ago and it ran rough, and made a lot of noise. I though the exhaust pipe had moved off the exhaust manifold because the bolts on the clamp were loose. I tightened those & the head bolts which were slightly loose. Didn't help so I cleaned the plugs, no help. Ordered new exhaust/tail pipe gasket, didn't help. Put new champion W18 plugs in today because that was all I could find local, didn't help. Did a compression check & no compression in #2. Crap! though I had a broken rod or piston. Stuck a wire in the plug hole & felt the piston going up & down. Only thing left is a stuck valve. Pulled the valve cover & saw the ex valve not moving. Checked on the Ford Barn & got all the ideas to unstick the valve.
And Thats The Rest of the Story. Good Day
Need to change the oil because it didn't look that good in the valve chamber. Not sure if I put the discoloration in the oil or not.
I was invited to show my car in the Northville Mich Concours d’Elegance on Saturday so I was desperate to get it running. Its about a 10 mile drive to Northville from my house. After the show the pressure will be off to get the car running right.
Thanks again for all the help.
Gene
