bambooboy
have started trk 5 or 6 times over winter.80 degrees today thought i should take a short spin.pressed starter, nothing ok dead battery. on charger came back 1 hour,pressed starter,nothing.pulled off starter switch,looks ok.used jumper across 2 terminals. nothing, warm lug.disconnect batt&removed starter bolts,starter stuck.put in 3rd gear & rocked till starter fell loose.everything looks good.question is WHY&grease on starter gear or not. thanks tom
